3 Piece Rough In Basement
Discussion in 'General Plumbing Help' started by PAUL Vincent SIKORSKI, Aug 19, 2019.
  1. Aug 19, 2019 #1
    Aug 19, 2019
    west grove, pa
    Hello,
    I have an unfinished basement and opted for the 3 piece rough in versus the 2 piece rough in. I have 3 pipes sticking out of the concrete basement floor, (1) larger one assume is toilet, (2) 12" behind the toilet along the wall is a 2" pvc pipe, (3) then in the middle of room is another 2" pvc pipe.
    I assume(1) is toilet, (2) is sink drain, and (3) is shower drain. However, I can tell if (3) is in fact for the shower because unable to see if there's a p trap below grade. Is it possible that they would have put a p trap some 3 feet away under or near the toiler drainage, and then into my sump pump container located below grade ?
    I poured water into the shower drain (3) and the water ran out into the sump pump container. I'm just concerned that perhaps (3) is not a shower drain, and furthermore, that (2) is not a sink but rather a vent for the toilet.
    Any help that can be
  2. Aug 21, 2019 #2
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    not a Junior Member anymore! Sponsor
    Mar 9, 2016
    791
    154
    NOKESVILLE, VA
    If it was roughed in for a shower, then yes it would be out from the wall a bit. Poor water down the pipe and if you see it there is a trap.
  3. Aug 23, 2019 #3
    Aug 19, 2019
    west grove, pa
    Thank you for the reply. I already poured water down the drain, but couldn't see the water sitting anywhere, so there's definitely not a trap directly below the shower. I'm not sure if they would have put a P trap further away, near the toilet / sink plumbing, for whatever reason ?
    Are there any tricks to figure out if there's a P trap in the system somewhere ?
  4. Aug 23, 2019 #4
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    154
    24
    Maryland
    Sounds like you built the house. Can you ask the builder what was done?
  5. Aug 25, 2019 #5
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    843
    193
    Mansfield,, Ohio
    The only other trick is have a drain cleaning company run a camera in. I doubt if they put a running p-trap down the line though.
    You might have to break up the floor and put a 3" ptrap in.
  6. Aug 26, 2019 #6
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    Mar 9, 2016
    791
    154
    NOKESVILLE, VA
    Every rough in I ever did had a trap in the ground
  7. Aug 26, 2019 #7
    SHEPLMBR
    SHEPLMBR
    SHEPLMBR
    Mar 9, 2016
    791
    154
    NOKESVILLE, VA
    pictures would also be helpful
  8. Aug 28, 2019 #8
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,612
    281
    North Reading, Mass.
    Is that sump pit for more than your basement?
    How many lines enter the pit?
    I have arranged a sump pit to act as a trap for various municipal/industrial applications. Don't know if it's legal for residential.
  9. Aug 28, 2019 #9
    VTplumber
    VTplumber
    VTplumber
    Aug 28, 2019
    Vermont
    Blow into the pipe, if air comes out the other end, no trap.
  10. Aug 29, 2019 #10
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    843
    193
    Mansfield,, Ohio
    If that is a shower line going into a sewage pit then it must have a trap put in.
    SHEPLMBR likes this.
  11. Aug 30, 2019 #11
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    190
    35
    Chicago suburbs
    You can get a waterproof inspection camera very cheap.
    I’m not saying to get this exact one, just posting a link to show what I mean.
    I got a nine foot waterproof snake type camera a few years ago, I use it for all kinds of jobs where you want to see into a wall, to look before you plan a route for plumbing or wiring,
    Or behind or under an appliance, into a ceiling, whatever.
    It beats cutting big holes that need patching.
    If you buy one to see if you have a trap, you will use it again many times.
    Or maybe you can rent one, but they are cheap.
    The one in this link is about $40.00.
    https://www.amazon.com/Semi-rigid-Endoscope-Borescope-Inspection-Smartphone/dp/B0785H3XR7
  12. Aug 30, 2019 #12
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    190
    35
    Chicago suburbs
    And yes, post pictures!
    Is there some way that “Always Include Pictures” advice can be posted to this site, on the sign-in page, in giant flashing letters?
    Maybe it is there, and I missed it.
    breplum likes this.
  13. Sep 1, 2019 #13
    Aug 19, 2019
    west grove, pa
    Hello everyone, thanks for the replies. Attached is the picture. I am essentially standing on top of the pit where the sump pump will be located.
    To answer a question from another response, there is only one pipe entering the pit, and assume all 3 pipes sticking out of the ground are connected under the ground and eventually the pit. As mentioned previously, there is definitely NOT a P trap directly below the pipe that is in the middle of the room.
    The clowns that put the rough in some 15 years ago, placed the toilet about 2 feet from the wall, and may have put the shower pipe in some other area that I was not happy about, so they re-did the plumbing hence why you can see new cement work. At any rate, I just need to know if the pipe coming out of the ground (assuming the shower one) has a P trap somewhere in the system which is compliance and correct.
    Thanks again all .....
  14. Sep 1, 2019 #14
    breplum
    breplum
    breplum
    Nov 14, 2017
    229
    86
    Lafayette, CA
    That pipe in the middle of the room, if it is going to be a shower, needs a p-trap right there as code requires.
    Also, I highly recommend Liberty sewer ejector systems. I only recommend the duplex (twin pump) system. It comes fully pre-assembled, and includes the high water alarm and electronic panel.
  15. Sep 1, 2019 #15
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,496
    2,346
    insert your measure tape into the pipe you believe may be the shower/tub drain
    you can ease the tape down the pipe, you can ''feel'' if you are going into an elbow or a ptrap
Share This Page
