I like moen,( autocorrect) and they make large trim covers., take the trim off yourself and see What's leaking and take a picture
I like men, and they make large trim covers., take the trim off yourself and see What's leaking and take a picture
autocorrectWell alrighty then
Yes, there are screwdriver stops on the valve. The one on the left is blocked by a piece of metal. Since another plumber is scheduled for Friday, didn't try to turn on water supply and test the valve. I will definitely ask the plumber to test the valve, and test the screwdriver stops. I will report back when I know more. Thanks all - the feedback is much appreciated!
Is this the Kohler K-304 Pressure Balancing Valve that @breplum had mentioned?
If so, and if it truly is leaking, does it make sense to replace it with another Kohler valve, or does it not matter at that point?
Yes., that's a must., clear bathroom silicone, clean up with a sponge. unless you want white caulking.Should caulk be installed around the trim?
It is not reasonable to have him no-charge isolating that valve, there should be screwdriver stops on the valve. If not there, that is original builder stupidity.
So is not making access available on the backside of that wall. What's there? A closet? Another room? SOMETHING has to be on the other side, and unless it's another tiled wall it's probably easier to work from there.
