Mikey
I'm replacing an old tub with a barrier-free ADA shower. The current drain is 1/1/2", and code requires a 2" in the shower. What's the likelihood my local inspector will allow me to retain the 1 1/2" drain for the shower? Aside from being a very difficult conversion, it makes no sense to me (not that that matters). The flow rate when you empty a filled tub is dramatically higher than the 2.5 GPM maximum in my shower, so why the need for a larger drain? (You may have guessed I'm not a plumber. I'm an electrical engineer, and this rule is (to me) the equivalent of requiring a 15A circuit breaker for an old CRT TV, and a 20A breaker for a new LCD.)
