Overflow and drain angle on acrylic tub
Pinne Plutt
Apr 19, 2018
6
I'm installing a new tub. The side where the overflow sits is slanted, I'd say 12-15 degrees. My problem is that none of the overflow/drain kits seem to accommodate for that angle. The fittings are 90 degrees. And the drain I need to connect to coming up from the floor is square with the floor. The old shower/tub I'm replacing also had a slanted side. And that overflow connector was angled. I have saved it but haven't found any hardware that connects well with it.
The new overflow connectors I've looked at come equipped with a thick foam/rubber gasket. It seems like it might be possible to force/bend them to accommodate the angle. I have one like that at home and am trying it out. It's threaded and has a nut on the inside of the tub.
I'm wondering if the foam gaskets are made to deal with being angled and squeezed like that and am worried about the possible stress on the tub wall where the overflow is.
Here's the angle without applying force on the foam gasket:
Here's what I need to connect to the drain in the floor and also be square with the drain:
Am I just making to big of a deal of this and it's non-issue - just go ahead and force/bend?
Nobody at Lowes/Home depot or the place where I bought the tub could give me a straight answer..
Anyone?
there are kits out there (gerber) the gasket is thicker on one side than the other.....you can just buy that gasket at a plumbing supply house......can you square it off after dropping thru the floor???
Not sure, but I believe a "beveled tub gasket" will solve your problem. My orange big box carries them, but, if yours doesn't, go to a plumbing supply house. That gasket is much thicker on the bottom than on the top, which should cause your overflow pipe to come off at 90 degrees.
I found out there are 60 degree bends in abs so I put a 60 and a 45 together and got 15 degrees which was good enough.
Well, turns out this didn't work. I didn't have all the parts in place in the tub. Just outlined on the floor. When I tried mounting the bend was to tight on the bottom of the tub.
This is what happens
When square
So it doesn't really matter whether or not the rubber/foam gasket is thicker in one end.
