Toilet shim advice requested
20GT
Oct 9, 2016
15
Hi plumbing people. I've used the plastic shims but they seem really hard to cut. Do you recommend using a wood shim? Or any cutting suggestions?
Wood + water= ......
Make a mark where need to be cut it, pull it and use an small hacksaw.
I use the white ones that are a little softer.
Those are hard to cut but they will cut with a SHARP utility blade.
Just takes a bit more effort. You could heat the blade up with lighter.
Just be careful if you have vinyl floor under it.
  • Like
Reactions: SHR
They actually cut very easily but you have to have a wood chisel. They shear very nicely with a firm/smart tap of a hammer. They are great. You don’t have to remove them and I’ve never had a problem and I have been using them for more than 25 years
Home Depot sells black plastic wedges that have breakable areas.. I used them before they work great
Pennies or stainless washers.
