Call a plumber
Before you damage valve body past the point of repair stop and call a plumber if you damage the body ,valve is not repairable and you will end up needing to open wall to replace valve body
TAKE OUT THE RETAING CLIP FIRST.Sooo, I have the same issue. Can it be "chiselled" out?
no, the retaining clip is clearly visible.You can follow the advice up above, about drilling some holes in the plastic, putting in some screws, and then pulling on the screws with pliers, to try to remove all the plastic chunks.
But by the way you have already mangled the brass valve body, I vote that you stop and call a plumber.
It will be too easy for you to cause more damage to the valve, which will never be fixable.
It might already be too late.
