My new Bradford-White water heater is set to 132. The upper limit works fine, it shuts off right at 132. That is fine. However, during the night, the temperature might drop as low as 115. Happens occasionally during the day, too, probably when I don't run enough hot water to cause the thermostat to kick in (at 114-115).
Of course, taking a shower in the AM causes the burner to begin to heat it back up to 132. But---several people might need to take a shower starting with a tankful of 115-degree water.
My old heater kept the temperature much closer.
It has the Delta 650 gas valve.
Is this too much of a temperature drop? Seems like it to me.
Thank You,
Vicki
Thank You,
Vicki
