Hi folks,
My daughter (in Laguna Niguel in southern California, in case that helps identify the device) has a leak in her outside plumbing. Attached is a wide-shot and a closer picture of the problem area. I couldn't attach a video because it was too large.
So, from top to bottom, there is a spigot with its shutoff valve, some device whose function I don't know, and a shutoff valve. I believe the water source is the top pipe since my daughter said the bottom shutoff valve was closed tight. Where does the bottom pipe lead to?
The leak is where the cap covers an outlet of the unknown device - right by the black parts (due to chipped paint, I think) of the pipe. I'm trying to find out whether the black part is porous.
Can anybody help with what this center device might be? Whatever it is, my daughter said she had tried to tighten the screw on the cap, but that didn't help. Assuming nothing is corroded, maybe a gasket or a seal needs to be replaced?
Thanks,
Jae
Thanks,
Jae
