Removing threaded nipple from cast standpipe
Bill McLeod
Jun 24, 2019
Michigan
Hey everybody, this is my first post. Im in the process of replacing 1 1/2 drain pipe coming from kitchen and draining to a cast standpipe in my bathroom wall. Im stuck at Removing a rotten threaded steel nipple from the cast standpipe. Any advice on how to proceed with this?15615082671636421779658827533549.jpg
another way is to cut the nipple close to the cast iron threads in a few places close together...then use a hammer and small chisel to remove the slices you cut that will leave an open space were you would use the hammer and chisel to somewhat crush the nipple so its smaller than the threaded opening and you should be able to pull it out.....this would be you last option just because you could damage the cast iron fitting if your not careful....
No serious attempt has been made to unscrew that nipple. Big pipe wrench and a lot of elbow grease usually gets it out. Old nipple is ALWAYS destroyed during removal so that one looks untouched.
Penetrating oil , before and after heat .
As a last resort , Big Hammer and chisels , as has been suggested .
Best of luck to you .
Wyr
God bless
Unless it's a hydraulic nipple a pipe wrench has a real good chance of only egging the nipple. penetrating oil - don't waste your time. As previously mentioned, cut it off flush and then split it by sawing. If you are an X-pert with a saws all go at it. If not clamp a hack saw blade between a couple of strips of wood and cut on the pull stroke. You'll be able to feel when the teeth first contact a thread. If the length isn't cut off, one cut often does the trick using a couple of hammers, 1 as backup. Cut off, 2 cuts may be necessary.
Not many plumbers have a Proto easy-out that size.
Good job
,but You were lucky it didn't deform worse. If there is ever a next time consider putting a socket in the nipple to reduce the deformation some.
Good idea , using the socket on the inside of the nipple .
Glad the heat worked ! :)
Wyr
God bless
