Water Filter
rickwhoo
Jun 25, 2010
256
88
Moscow Pennsylvania
My water comes from the ground with a well pump. I want to add a water filter for the purpose of keeping the sediment from clogging my aerators in my faucets. What filter system should I buy?
https://www.tractorsupply.com/tsc/product/water-source-well-system-sediment-filter
This Water Source Well System Sediment Filter is used in water well applications to reduce sediment in-line for sprinkler systems and whole house systems. It also helps make pumps, well tanks, sprinkler heads, and all plumbing fixtures last longer. This filter includes a 100 mesh stainless steel screen.
  • Ideal for pre-filtration where well pumps are used
  • Filters out sand and other sediment from well or irrigation pump applications
  • Protects plumbing fixtures, washing machines, pressure tanks, small and large sprinkler heads
  • Sediment is visible through clear bowl, making it easy to know when to flush
  • Replacement filter screens are not available in store
  • Please contact manufacturer for replacement filter screens (sizes ranging from 30 mesh to 500 mesh)
  • This does not replace the need for a whole home filtration system
  • Fits 1 in. and 1-1/2 in. pipe
WOW! Great! I didn't think there was there was going to be something so in-expensive to get for my needs. This looks great!
