Replace Kohler oversized tub drain with standard size - possible?
BikeNHV
Mar 26, 2019
New Haven, CT
I have an older cast iron tub with what appears to be a Kohler Clearpass drain system. This is an "oversized" drain - the drain shoe is 2" and the OD of the drain trim inside the tub is 3.1" (As opposed to about 2 3/4" of typical modern drains).
I would like to refinish the tub, and ideally remove the entire drain assembly and replace it with a modern Gerber drain like the one below. What I would like to know before disassembly is if anyone know if the tub will have enough "meat" around the drain to seat the smaller 2 3/4" drain?
If it doesn't, I will have to source some repair parts for the existing drain.
Diagram of existing drain:
https://www.guillens.com/kohler/Kohler SP4 (D)/svcparts/pdf/087926_8.pdf
Gerber drain assembly with universal drain size:
https://s3.amazonaws.com/gerber-gh/579a4f24818af64912fbbb79/41-813.pdf
Good discussion on this drain type here, but unlike in this person's case I'm not attempting to salvage any of the existing drain assembly. I'd like to replace it completely:
https://www.plbg.com/forum/read.php?1,335384
