Bvdave
I have an odd problem, the taps in my upstairs bathroom randomly stop giving water, if i open the taps nothing happens. If i go downstairs and turn on the tap it will start slow for 1 second then go normal and i hear the upstairs tap kick in.
This seems to happen mornings after water has not been used overnight.
This started happening a few days ago. The water pressure tank gauge shows about 27-28 psi constantly. (Technically the gauge is on the main water line a few inches from the tank, not on it... unsure if thats proper or not. When i knock on it it sounds empty.
Suggestions appreciated.
