Damian Marshall
Hello,
I am moving a PVC plumbing vent on my shower drain as part of a bathroom remodel. the only problem is that all of the fittings near the plumbing vent have basically no pipe between them. How do I remove the plumbing vent and tie back into the drain if there is no extra pipe between fittings to tie onto? Is the only way to cut it all off at the vertical pipe and start from scratch? There is not a lot of pipe sticking out on the vertical section so I hope that is not the only way. Picture of my situation attached.
Thanks in advance.
Thanks in advance.
