inserting fitting into existing line is this code?
geoffhazel
Jan 7, 2011
47
Seatle, WA
I need to insert a fitting into an existing 2" abs line that's fixed on both ends. I was thinking of sliding a fitting halfway to "tight" and slipping it in then sliding halfway back on the other side which seems sketchy not to say "not tight" and then I saw these. are these "code" ? It's going to be buried in a wall.
If not what's the right way to do what I need to do?
This NOT the correct way to install that tee
to correctly glue a pvc joint you must twist it after you insert it. assembly shown in this picture does not allow you to correctly glue the pipe together
to install that tee. you would glue one joint and install 2 proflex bands
Don't know about the labeling but I don't think you want the one that has the No. 3001-22 but rather the Fernco / Proflex No. 3000-22. Looks like that 3001-22 is a transition coupling. ???????
Yes 3000-22 is the 2"- 2". Got three of them tonight at HD.
