[SOLVED] Final reply contains cause and solution.
Hello all, I am not versed in plumbing at all. So I am just going to dump all the info out here and someone experienced can decide what matters/is related and what is not. This downstairs bathroom that I will be referring to is something that was added well after the house was built (@ 1960). We did not build it though, it was like this when we bought it about 5 years ago.
The problem started about a week ago when I noticed water leaking out onto the floor underneath the basement toilet. We naturally thought it was the wax ring, and so we replaced it. The wax ring was in bad shape, almost nearly gone, and so we thought the problem was fixed. After putting everything back together though, the toilet was not draining properly. Thinking back I specifically remember seeing standing water in the pipe in the floor. I should have seen that as a red flag, but again this isn't my type of thing and after seeing the previous wax ring I wasn't thinking there was another problem. It was only after we put everything back together and the toilet was not draining that made me think of that. I have since snaked that drain for 25-30 ft. and couldn't find anything.
The problem in short is that the basement toilet only drains very slowly. I can flush without overflowing it but it does not empty the contents as the water level just slowly drops. If any of the two toilets upstairs gets flushed it gurgles the basement toilet and then sucks almost all of the water out of it. These are not directly above the basement toilet, about 10-15 ft. to the left of it which is the main sewer stack.
It seems to me that it would have to be a venting problem, as the only thing I can think of that would pull water out of that toilet is the vacuum created when the upstairs toilets are flushed pass by where the downstairs toilet drains into the main sewer line. It tries to pull air from there but if the vent for that line is blocked it tries to pull it from the toilet instead. This is where I need an experts help though, because it may seem like that is the only way but I really don't know enough about plumbing to know if that is actually true or not.
Another problem is though, that the sink right next to that toilet drains fine (more on this in a bit). Although I stated that this bathroom was added well after the house was built, the drain for the sink does seem quite old so I have no idea if it actually connects with the toilet drain. I would think so as the two drains are merely a couple of feet apart, but again I am clueless about this type of thing. This same sink had been having problems draining for a month now, and I thought the problems were related. However, earlier today I took off the p trap to try to do some snaking and in putting it all back together the pipe connecting the main drain to the p trap broke off it's lip. It was an older metal pipe and the lip just rusted and broke. I went and bought a PVC replacement though and after putting it back together, the sink no longer had any drainage problems while the toilet still did.
Also, I cannot find the vent for the basement bathroom. The sink and the toilet both drain directly into and then under the concrete, and there is no piping going into the wall at any point. I know it has to have a vent somewhere but I have no idea where it is. I know from going on the roof that there are three vent pipes - the main sewer vent which is the 3-4" one and two smaller 1 1/2-2" ones. One of the smaller vents is directly above the kitchen, so that one is obvious. The other small vent pipe though is within 10 ft. or so of the main sewer vent and because one of the upstairs bathrooms and more specifically the shower/tub in that bathroom is almost directly above the basement bathroom I have no idea if that other vent is for that shower/tub, the downstairs bathroom, or both.
Other issues include the basement floor drain overflows (not by a lot, it never overflows more than a few inches around the drain) when any appliance is drained and then drains slowly as well. This is also a new problem, and so almost surely related. It kind of bobs up and down as it drains, not dramatically but still noticeably. That drain is pretty close to where the bathroom drain is, but how the pipes are run under the concrete I have no idea, though I do know the toilet and sink drain are only maybe 10 feet or so away from this floor drain. I realize these drains are probably not directly connected but I thought maybe their proximity might matter.
I have no idea whether this next issue is connected or not but a while ago we started getting a really bad sewer smell in the house. It wasn't a constant smell, just once in a while - roughly once a week, maybe once every two weeks. The hall bathroom upstairs previously mentioned has two sinks and a shower/tub. They do not get used much so after reading up about it I thought maybe the p traps had evaporated and so I started running water through them periodically. That was about a month ago. It seems to have worked as that smell hasn't come back - yet. It has only been about a month so there is at least a chance it hasn't happened again, but I really don't think it ever went a month before where that smell didn't happen.
That is all of the info I have, and as I said some of it may not even be relevant but I thought someone more experienced should make that call. I appreciate anyone taking their time to read this post and help me solve the problem. I will run any kind of diagnostic that I can to help gather more information if it is needed, just let me know what you need. Again, I appreciate any help anyone can provide.
[EDIT #1] I realized that I did not specifically state that no other appliances are having any problems draining. Other than the ones I mentioned - sink next to the toilet in question was having problems draining but after replacing the s pipe/trap it does not, and the floor drain in the basement. Every other appliance drains normally.
