Royalwapiti
About three months ago I installed a Liberty backup pump and at the same time I changed the check valve on my main sump pump. It was a Zoeller green one and noisy. I switched to brand called Klunkless, it was quiet for about 3 months, now it is noisy. It gets a lot of use. After a rain my pump runs for 9 seconds and is off for 16 seconds, then on again. It gradually increases the intervals. Now it is running for 9 seconds every 2-3 minutes. It's like that all spring summer and fall. The sump pump drain riser goes up an 8 foot basement wall and to the outside.
Does anyone have suggestions for a good quiet check valve? Are the clear plastic Zoeller "Quiet Check Valve" any good?
Thanks
Thanks
