jerryinsocal
Just outside the house there is a connection made with a banded no-hub coupler that connects two slightly misaligned sections of pipe. Roots are able to get in and clog the line about every two years, basically because of the misalignment. There are too many bends, wye's and short pieces of pipe to do a re-pipe without a major overhaul of the area. I am considering installing a two inch PVC pipe with a screw cap directly over the new no-hub coupler I have just installed. It would not be connected but would be open at the bottom. This would enable me to periodically pour something down there that would keep roots away from the coupler. Does this sound like a workable idea, and if so, what would you suggest the product to be poured in might work best?
