jen rau
The original problem is that the spigot leaked incessantly when the handle was turned off. I took it apart, replaced spigot (for another problem) and removed what I thought was an old rubber washer. So I took it all to OSH and they didn't have any of the parts but I found a washer that almost fit. I put it all back together and no leaks. But the handle started to go further and further past off before it was off so I thought the washer was failing. So today I went to the plumbing specialty store. They said I needed packing and sold me a kit with that and the other piece that screws to the stem and has the hot and cold. So I couldn't get the packing in deep enough to screw the threads of the other piece back on. So I cut it in half and stuck it in there and put it back together. NOW it leaks out of the handle. AFTER having the right pieces. What to do now?
