Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > How do I remove a Bathroom sink faucet that has no screws?
Thread Tools Display Modes
Old 12-17-2010, 05:57 AM   #1
Brianm
DIY Member
Default How do I remove a Bathroom sink faucet that has no screws?
Help! I need to remove the handle from my bathroom sink faucet but it has no screws. There is no cap or holes where a set screw may be. I also have no clue on the manufacturer of this faucet since it was already installed in the house when we moved in. I also uploaded some photos in m album so you can see what it looks like.
http://www.plumbingforums.com/forum/...albums/faucet/
Brianm is offline
Old 12-17-2010, 07:41 AM   #2
DUNBAR PLUMBING
MASTER PLUMBER
DUNBAR PLUMBING's Avatar
Liked 11 Times on 9 Posts
Those handles should unscrew up to the brass trim rings, and there's either a allen screw or phillips screw at that point that loosens it up.
Looks like a Moen but I'm not sure. I doubt it's a Monticello as they has larger bases to the faucet.
Maybe someone else has some pertinent info relating to that style.
DUNBAR PLUMBING is offline
Old 12-17-2010, 10:55 AM   #3
SlowDrip
Plumbing Sales
SlowDrip's Avatar
Liked 1 Times on 1 Posts
Not any moen I am familiar with, nor delta. It looks a little like a price pfister in the shape of the handle, but not any that are currently on the market. Gonna have to wait for the cartridge reveal on this one.
SlowDrip is offline
Old 12-17-2010, 03:07 PM   #4
Mr_David
Easily Amused
Mr_David's Avatar
Liked 895 Times on 726 Posts
Likes Given: 592
Click free
a.k.a. Krazedav
Mr_David is offline
Old 12-17-2010, 03:21 PM   #5
Brianm
DIY Member
Do I unscrew the bell shaped escutcheon or the brass ring that's on top of it (just below where the handle enters the escutcheon)?
Brianm is offline
Old 12-17-2010, 09:23 PM   #6
SlowDrip
Plumbing Sales
SlowDrip's Avatar
Looking at this picture when I am fully awake, it strongly resembles an American standard Amarilis Iris.
If it is an A.S. faucet, you can find the install sheets here, step 14 is an exploded view of the handle assembly.
SlowDrip is offline
Old 12-18-2010, 12:05 AM   #7
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
My guess is that the bell shaped escutchion will unscrew, if you can grip it firmly enough. The Kohlers of that style that I have seen do, and I believe the Moens as well.
phishfood is offline
Old 12-18-2010, 03:41 AM   #8
havasu
Administrator
havasu's Avatar
Liked 1130 Times on 922 Posts
Likes Given: 350
You should be able to get a wrench on the underside and after removing all the slide in washers, it should lift out of the hole.
havasu is offline
Old 12-19-2010, 01:55 PM   #9
Brianm
DIY Member
Thank you all for your help.
Brianm is offline
Can't remove faucet to replace washer - HELP! brownknows99 Toilets and Sinks 3 07-02-2012 09:22 PM
Changing from single sink to double sink in bathroom keith5523 Toilets and Sinks 1 09-25-2011 02:32 PM
Trying to open a faucet without screws Pazu Showers and Tubs 2 08-05-2011 10:50 AM
How to remove valve stem in single handle bathtub faucet. wndrwmn67 Plumbing Tools and Equipment 20 03-12-2011 06:51 AM
Newest Threads
