Just bought a home built in 2007. I have great water pressure in the entire house except for the master shower. The whole house is done in Pex. The basement is finished with a drop ceiling, but I can see what looks to be a professional job and I can follow the entire system to each section of my house.
The only thing I can't see is where the pex heads north into the wet wall behind the shower. I don't have an access panel behind the shower nob or shower head, but if I had to cut an access, I could do so through our walk in closet.
I've taken the shower head off and turned on the water and it just limps out. I've tried to adjust the pressure through the knob, but it's always set to the max.
In the master bathroom I have double sinks, toilet and a separate tub all plumbed with pex and seem to have great pressure. The tub has a separate wet wall and is not plumbed together with the shower. The sinks and toilet are opposite the shower and tub and are plumbed with their own wet wall.
I have an upstairs shower that has pressure that blows you against the wall, but this mystifies me? Why pressure in the entire house except the master shower? Should they have reduced the size of the line when it turned north from the basement to the shower?
Any thoughts or suggestions would be helpful.
emanoh
emanoh
