help with by bottom shower faucet
rsingh777
Aug 12, 2016
i have an old faucet and i can't afford to replace it now but i have a small issue.
in my bathroom tub the bootom faucet flows fine but when i have to pull the leaver so the water can flow through the shower it does not work because the rubber under the bottom faucet is old and worn out. (see pics attached)
is there any replacement rubber i can use or any idea how to fix
Thanks for all your help!
If parts are available and diagrams to help you repair the spout, you may find them through contacting Moen. They are very helpful and will provide information to send the pictures that you took for identification and part numbers. I think that's a Moen Moenique tub/shower faucet and trim. Here's the contact info for Moen.
http://www.moen.com/customer-support/contact-us
  • Like
Reactions: SHR
