Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > basement bath
Thread Tools Display Modes
Old 01-08-2010, 03:26 AM   #1
erndog02
Default basement bath
Hi I am looking into the future for a basement bathroom and possible kitchen. My sewer outlet is 3 ft high on the wall. I am a hard core do it yourselfer(cringe) and am not worried about cutting the slab and running the pipe but I am curious about your experience with how well sewage pumps/grinders work.thanks in advance
erndog02 is offline
Old 01-08-2010, 04:34 AM   #2
'Cause
My drains are stopped up
'Cause's Avatar
Liked 1 Times on 1 Posts
I'm going to guess that the invert elevation of the waste line is below the slab, are you sure that what you see "about 3' above the floor" isn't a cleanout?
Are there floor drains in your basement?
1. Stupidity should be more painful
2. Don't believe everything you think
'Cause is offline
Old 01-09-2010, 02:01 AM   #3
erndog02
My house is on a sloped hill and the builder(back in the 50's) put the main sewer drain elevated 3 feet above the basement floor. I dug out a tree behind the house and found the main sewer line(3 inch hard plastic pipe, probably pvc) below the root ball. This pipe was in direct line between the pipe exiting the basement and where the city's records say I connect into the sewer system. the pipe was a good 3 feet below grade at that point. I am including a pic of the clean-out/ exiting pipe
erndog02 is offline
Old 01-09-2010, 02:08 AM   #4
erndog02
Default basement bath part 2
And as far as drains in basement, only one that is a standing pipe in laundry room. it stands vertical about 2.5 feet tall. I have been draining washer into it with no probs so far. I'm guessing it drops into weeping drain system. The basement is on grade(to right of pic) and has an asphalt slab out the door. I dug into it for a post at one time and found a layer of 1 inch rock under it, the rock layer seemed to be about 2 feet deep.
erndog02 is offline
Old 01-09-2010, 02:09 AM   #5
JWPlumbing
Effluent pumps work fine. I have install several of them just make sure you install gate valves on both sides for any future repairs and also run a vent.
JWPlumbing is offline
Old 01-13-2010, 01:49 AM   #6
FixturesEtc.com
FixturesEtc.com's Avatar
Default Basement toilets
Hi,
Have you thought about Saniflo the upflush toilets? They are awesome!
FixturesEtc.com is offline
Tags
basement toilet
Bath Venting ddocfletcher General Plumbing Help 14 03-04-2012 08:38 PM
Tying new basement bath into main SimpleComplex General Plumbing Help 4 12-18-2011 03:36 AM
Basement Rough-In Full Bath Questions pingman3 General Plumbing Help 1 11-30-2011 11:58 PM
Adding Bath Tub To Basement Bathroom DankMasterFrank General Plumbing Help 0 06-15-2011 06:43 PM
Bath Drain Puddy General Plumbing Help 1 04-28-2011 12:26 AM
