Silicone to stop a leaking radiator?
Thomas5
Mar 30, 2012
7
Hi
A fairly basic question - on a bathroom radiator there is a leak (from the side as shown in photo). This is a slow leak - maybe one drip every 2 days. The maintenance man looked at it and tightened it as much as it would go, however it is still dripping - but very slowly. Maybe one drip every 3 days. Someone suggest Silicone would help if spread around it (I have done this - rather messily). I used Unibond silicone sealant. I found a bit of water on the outside of the silicone today, not sure how it got there.
Should I:
1) Leave it, if it drips then it drips and it might seal itself through oxidisation
2) take the silicone off and replace with Fernox LS-X which I have read is good.
3) Call someone out
Any help for this amateur would be grateful :)
Thanks
Tom
Thank you! I'll get the chap in. I had hoped I could avoid a call out charge - but better to be safe than risk burns (and probably a flood)
