Fleck 5600 softener(5E45-2 media tank) salt regen settings?
havoc2000
Jan 30, 2016
So. Maine, Maine
Hello all- Im hoping someone can point me in the right direction with my Fleck 5600 ecominder water softener. Its a basic model, 1.5cubic foot tank 54" tall,10" diameter( I believe it's a 48000 grain tank), with a 12 day timer, which has pins to set the regen frequency. I live alone, and use very little water. I feel its regenerating too often, as when it was installed in 2011, it was pre-set to 18lbs per regen, every 6 days at 2am. I recently lowered the salt per regen to 8lbs from the 18lb factory setting. The installers said they don't usually mess with the default setting, and left, so now I'm wondering WTF? lol. My water specs at the time of install are as follows: PH 7.1, Total Hardness 51.4 mg/l, nitrate nitrogen 10. mg/l, arsenic <.5 ug/l, calcium 17 mg/l, copper .022 mg/l, Iron .31 mg/l, lead ,72 ug/l, magnesium 2.2 mg/l, manganese .0023 mg/l, sodium 40. mg/l, turbidity 3.9 NTU, and uranium <.5 ug/l. I know this is a lot of info on water, but I want You people who understand to have the proper info. I hardly am ever home. I shower every am, all water appliances are low flow. Do maybe 5 loads laundry a month, with an HE washer, run dishwasher 2x a month, etc. I don't think I even use close to the 70 gallons a day avg that I read online, but if I do somehow, could someone point me to figure out how many "Grains" of hardness my test equals out to, and recommend a regen\salt lb setting to start with? Right now, I'm set to regen every 12 days, with 8lbs solar pellets. I just set this a few days ago, so I could always change it back if needed, but even if I go on vaca, and run NO water it was pumping 18 gallons per regen, which seems crazy. It drains regen under my deck, but the excessive salt is actually starting to kill my lawn 12' away. I have a dug well, and live in the country. No town water fyi. Any info is appreciated! Mike
Your 51.4 mg/l translates to 3 grains hard. This is practically soft water already. I wouldn't have a softener if my water was that soft. It may be getting the iron out, but you should have been sold an iron filter not a softener. The best 5600 head was the one with the built in water meter that didn't backwash until X number of gallons ran through the unit. This is a real salt saver. The 12 day clock doesn't have enough days for your hardness. Give the bypass valve a quarter turn into bypass and see if you can even tell a difference in the water without the softener.
Thanks, Speedbump. I figured it out to be 3 grains also. I was thinking of maybe just unplugging it. Maybe on a monthly basis, go down cellar, plug it in, and do a manual regen before going to bed. I would leave the salt at 8lbs setting. The reason I got a filter to begin with, was because I was getting a reddish ring around my toilet water level, in the toilet bowl. This certainly did cure the problem, but I know I'm not needing to backflush so much. If I ran the backflush monthly, at 8lbs salt\brine setting, the normal 6 bags should last 30 months, instead of 6 weeks or so, and I wouldn't expect much of a difference in water quality, if any. As long as I do the monthly flush, I would think the filter media would be sufficiently cleaned with an 8lb backflush. Thoughts on that ?
