Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Toilets and Sinks > rocking toilet
Thread Tools Display Modes
Old 01-07-2010, 03:36 PM   #1
ancestralworm
Oh there will be crying.
ancestralworm's Avatar
Default rocking toilet
I just put down porcelain tile in my bathrooms and now one of my toilets has a very slight rock. Can I use something like a plastic door shim to fix this or is there a better way.
ancestralworm is offline
Old 01-07-2010, 03:39 PM   #2
majakdragon
You can get plastic toilet shims at hardware or Big Box stores.
majakdragon is offline
Old 01-07-2010, 05:32 PM   #3
Nailer341
Resident
Nailer341's Avatar
Liked 1 Times on 1 Posts
Are the toilet mounting bolts snug? confirm this as well as a bead of caulk around the base of the toilet.
Nailer341 is offline
Old 01-07-2010, 05:56 PM   #4
ancestralworm
Quote:
The are quite snug and I fear if I tighten them any more I will break something. I had to cut the old bolts off with a Dremel and the ones on now are new.
Old 01-07-2010, 05:58 PM   #5
Nailer341
Resident
Nailer341's Avatar
Caulked properly?
If so, shim away and re-caulk.
Old 01-13-2010, 09:43 PM   #6
Conway
Conway's Avatar
What did you end up doing Ancestral?
Conway is offline
Old 01-14-2010, 01:44 AM   #7
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
I use pennies for shims.
Cheap, abundant, resistant to decay. The plastic ones at the hardware store can be difficult to cut.
Reedwalker is offline
Old 01-14-2010, 08:31 PM   #8
ancestralworm
Quote:
I took majaks advice. I went to Lowes and picked up a pack of soft plastic toilet shims(who knew). Cut them with a razor knife and jammed them in with a flat head screwdriver. Totally invisible and worked like a charm.
Thanks,
worm
Old 01-15-2010, 02:11 AM   #9
Mr_David
Easily Amused
Mr_David's Avatar
Liked 852 Times on 693 Posts
Likes Given: 568
Here's how I set a toilet every time.
I set the toilet in place without the wax seal.
Always install new bolts and secure the bolts to the flange with nuts & washers.
Then put you weight on the bowl and check to see if it rocks.
Some times the flange is to high. You want the bowl to sit firmly on the floor , Not the flange.
Then I place shims until it feels firm.
Old school method was to make copper shims by smashing pieces of copper tubing, or a few copper pennies, but now they have plastic shims that work much better.
Lift up the bowl set you wax ring and reset the bowl.
Other problems such as the flange not secured to the floor and it may flex upward when you tighten the bolts. Shims won't help.
Mr_David is offline
Old 01-15-2010, 05:13 PM   #10
majakdragon
Glad the problem is solved. Thats why we are here.
If you have never made a mistake, you probably haven't done much.
Tags
porcelain, toilets, rocking, shims, caulk
Newest Threads
