Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Septic Tanks > Water softener on septic system
Thread Tools Display Modes
Old 01-07-2010, 03:13 PM   #1
bradyman1
jeepin
bradyman1's Avatar
Default Water softener on septic system
Will the discharge from a water softener cause problems on a septic system? I am talking about the backflow from the water softener when it does a cleaning cycle. I have a new low pressure drip systems, and it was leaking, bad. The plumbing inspector told me to take that off, I did and several months later it dried up. I also ran a permanent drain from my old septic field, the 10" corrogated sock pipe to daylight because I was getting a lot of surface water at the bottom of my old field. 1000's of gallons must have ran from that pipe. It is always wet where I drained it to. Before I did it the engineer told me to run a "down slope interceptor" drain in the same location. He told me the water table was to high. Does any of this sound feasable? I know running the old drain field to daylight really dried out the bottom of my yard!
bradyman1 is offline
Old 01-07-2010, 03:46 PM   #2
majakdragon
All the softener systems I have seen discharge elsewhere, not in the septic tank. I always assumed that the discharge water had elements that could kill the bacteria that makes the septic system work. I could be wrong though.
majakdragon is offline
Old 01-11-2010, 08:13 AM   #3
Dennis/Ohio
The oxygen getting to the old system through your drain pipe will renew it in about 15 years like you never used it.
Code probably requires everthing to go to the septic system but Oh Well... I've though about using the softener discharge to de-ice the driveway. Seems like it would work.
Dennis..... DennisHoover.com
Dennis/Ohio is offline
Old 01-11-2010, 11:14 AM   #4
nhmaster3015
Master Plumber
nhmaster3015's Avatar
softener discharge will in no way effect the septic tank. Many many studies back that up.
When in doubt, hire a licensed professional
nhmaster3015 is offline
Old 01-11-2010, 04:07 PM   #5
bradyman1
jeepin
bradyman1's Avatar
The inspector said it was the salt in the discharge that would cause the leach field to not work properly. There are studies that show this to be not true? It wouldn't be the first time an inspector was wrong.
Old 01-12-2010, 04:55 PM   #6
bradthebard
neither a bird nor plane
bradthebard's Avatar
Quote:
You would have to pump a huge amount of salt into that field to do any real damage. I doubt your water softener is putting enough through to do any real damage.
bradthebard is offline
Tags
backflow, septic, water softener, drain, sewer
Water softener RockyRR General Plumbing Help 6 12-27-2012 01:48 PM
I need help selecting septic system scheek Septic Tanks 16 03-09-2012 07:32 PM
Water Softener Problem? IanB Water Heaters and Softeners 3 09-23-2011 04:04 PM
Need a water softener Otahyoni Water Heaters and Softeners 20 04-12-2011 12:34 PM
Old water softener system questions. Dsang97 Water Heaters and Softeners 4 12-28-2010 04:19 PM
Newest Threads
