I have been considering starting to use this PEX system for quite some time. Finally had a job that justified the $1000 expense to buy the press tools.
I am really impressed by these fittings so far. Low zinc content, so zinc leaching from the fittings is a non issue. 8 rings on the fittings, instead of 3 on a standard PEX crimp fitting. The rings are fixed on the fittings, so no problems with positioning the the ring on the fitting/pipe.
I have piped in 2 bathrooms so far, and I really like how it goes together,
