Downstairs bath
Scorpionkingct
Jun 28, 2015
I have two bathrooms one up and down. When I use the upstairs shower I get hot water, downstairs when I turn it th shower to hot it just stops the water? If my upstairs works I assume the hot valve is open and appears to be in my furnace room, what would cause cold water only for shower downstairs?
The valve that has no hot water... Is it a Moen Posi-temp?
Does it turn on counter clockwise from cold to hot. But no Hot
Replace the core. The balance spool in the core is stuck. This could also be true for other pressure balanced valves, but The Posi-temp is a common problem, especially when that valve is not used frequently
