Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Hydronic baseboard too long
Thread Tools Display Modes
Old 09-16-2010, 04:05 PM   #1
DIYerOnLongIsland
Liked 1 Times on 1 Posts
Default Hydronic baseboard too long
Help!
Hi, I'm a new member from Long Island. I am renovating an apartment in my home, and in doing so I removed 2 lengths of wall to wall "Sun-Ray" hydronic baseboards. The old BB's were rusted out, dented, painted poorly over the years and weren't worth saving. They were "spliced" along an 11' wall in each room.
I'm now installing new Slant-Fin hydronic baseboards. What should I use to shorten a baseboard where the splice is going to be, tin snips? A hacksaw?
Thanks in advance!
DIYerOnLongIsland is offline
Old 09-16-2010, 10:27 PM   #2
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
Tin snips work great for that.
Make sure they are sharp. I recommend "practicing" on the old stuff just so you can see how it's gonna go.
Also, be sure to install a "bleeder" 90 on the farthest turn from the boiler. This will help in any future repairs and your initial startup.
Reedwalker is offline
Old 09-19-2010, 01:19 PM   #3
DIYerOnLongIsland
Thanks Reedwalker. I actually saw a plumber in a van a couple days ago and asked him through the car window... recommended a hacksaw. I figured tinsnips might work, but wasn't sure.
I'd install a bleeder 90 if this was a typical installation, but it's not. The supply starts in the bathroom with a small 3' BB, 90's back into the wall and remains @ BB level until it 90's out the rear bedroom wall, where it enters the bedroom BB, right through the bearing wall into the livingroom BB, 90's for another 6' of BB then 90's down under the slab to avoid the entry doorway. After passing the doorway it 90's back up to BB height, 90's into the BB and remains that level until it reaches the boiler. So I think the smart thing is the 90 in the livingroom where there will always be that pocket of trapped water in the pipe in the slab.
[ bedroom wall bearing wall livingroom wall ]
[ 90's down into slab ------> 0
[ <--bath BB
[ 90's up into kit BB -> O
o<---up and over ceiling to boiler behind kitchen (--->) ] <- into boiler zone valve
How long does it take for a cloth towel to decompose? Dollar_Bill General Plumbing Help 8 01-27-2012 01:47 PM
help with baseboard system refill gregp553 General Plumbing Help 11 09-19-2011 11:53 PM
Long screwdriver down the drain AJay Drain and Sewer Cleaning 8 07-16-2011 12:45 PM
hot water baseboard parts bggas400 General Plumbing Help 0 03-06-2011 10:02 PM
Hot water baseboard heater bleed bggas400 Water Heaters and Softeners 0 11-30-2010 09:53 PM
