sailorman3
I have a 18 foot well at my cottage. I installed a on demand well pump last year that is digitally controlled so there is not need for a pressure tank. Had no problems all of last year. I drained the pump and system for the winter. When I started the system up for this year, the pump control pressureized the system and then when a tap was turned on the pump control went into failure and the pump shut off. This happens all the time. I primed and bled the system many times. I installed a new foot valve, changed all the lines to the well and even installed a new pump. Still the same problem. I'm out of ideas. Can anyone point me in the right direction. Thanks in advance.
