Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Recirc pump at full speed?
Thread Tools Display Modes
Old 08-16-2010, 02:21 PM   #1
dfuerpo
Default Recirc pump at full speed?
I have a hot water recirculation system with a Rinai tankless water heater and a 10 gallon electric buffer heater. About 18 months after all this was installed, the recirculation pump failed. It was a smaller Grundfos model the plumber thought that it had been undersized for the system. He installed a much larger Grundfos pump (model UP26-96BF). I thought that this pump was quite noisy, you could hear it in the upstairs master bath (the pump is in the basement), whereas the older, smaller pump was nearly silent. It started looking at the specs for this pump on the Grundfos website and saw that there were control electronics in the plastic box on the side. Being the curious troublemaker I am, I opened the plastic box to find that there was nothing in there. In other words, this pump has no controller circuit and is simply running full bore! My question is: is this a problem? Is it OK for this fairly large recirc pump to be running a full speed like this? Any help is appreciated.
dfuerpo is offline
Old 08-16-2010, 03:49 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1114 Times on 906 Posts
Likes Given: 336
I believe the original pump was not undersized, but having the system in your basement caused excess strain on it as it pushed the water to the top floor. If the pump shuts down with no water usage, or activates at a specific time, this just meant that the pumps control circuit was bypassed, and is utilizing the TWH's controller. If it fails to shut down at all, it would appear that the pump was directly wired, and I would have the plumber return and installer the controller.
havasu is offline
Old 08-18-2010, 04:15 AM   #3
greenplumber
Simple solution to this problem is to install an "On-demand" recirc pump. This is the only pump you should be using if you are using a tankless as it will not void the warranty. Secondly, it will only operate when you need hot water, thus it will last you about 15-20 years. Best one is the Metlund D'MAND pump.
greenplumber is offline
Old 08-18-2010, 04:45 AM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 336
I like that "on-demand" system but see two potential downfalls. First, if the TWH has a built in recirculating pump, you would have to gut the old one in order to install the new pump. This would certainly void the TWH warranty.
Another problem is the fact that the switch, either the push button, motion detection or remote control, has to be activated and then wait an amount of time before the pipes get hot enough to use. The concept is great provided you activate the pump, walk away, then utilize the hot water.
As long as your hot water demand is at a scheduled time, I prefer a fool proof timer.
havasu is offline
Old 08-24-2010, 11:19 PM   #5
Reedwalker
Expert Turd Herder
Reedwalker's Avatar
Liked 1 Times on 1 Posts
Piping a Rinnai with a 10-12 gallon buffer is in my opinion the very best method with a re-circ. The small tank is economical to run and service. It also relieves the "cold water sandwich". The Grundfos with a built in timer is a reliable and competitively priced unit.
As far as being undersized...........not likely. I service a 3 story building that uses a 1/100 hp pump for its recirc. It worked for 15 years before I changed it to a bigger one.
Reedwalker is offline
Recirc question desertwater General Plumbing Help 9 05-22-2012 12:22 PM
Question on Hot Water Heater Recirc. Pump beantech Water Heaters and Softeners 2 08-13-2011 02:28 PM
tankless+storage tank+ recirc= ? Vermontchill Water Heaters and Softeners 1 05-30-2011 02:05 AM
splitting a recirc line DD3 General Plumbing Help 2 03-31-2011 06:32 AM
Hot water recirc pump installed, now hot water in cold lines? hevykevy420 General Plumbing Help 0 09-09-2010 03:35 PM
Newest Threads
