Rookie/newbie question: is there a way to clean the third hole (mixed water out) in a Delta valve?
I get about 1 gpm flow with cartridge in; 7 gpm with cartridge out and water on. Delta has sent 4 cartridges but no improvement.
I've used hose fittings and garden hose with caps on tub shower stem in various combinations (cartridge in, cartridge out, water on, water off). I know there is no obstruction in pipe to tub spout, to shower head. I know water pours out of hot and cold holes in vale with cartridge out.
But water does not flow freely out of the third hole (mixed water out) when I attach garden hose on tub or shower stem and cap the other. (Back flushing.)
Delta insist the problem is a defective cartridge, but I'm now on my fourth one. Most of the agents do not seem to know there is a third hole in the valve. Am I crazy rookie or are they?
So is there a way to clean the third hole? I've tried wire, pipe cleaners, CLR.
Or do I have to hire a plumber and change the entire valve, cutting into walls or tile! Yikes!
