I had a hard time getting the handle off. The screw stripped so I roto zipped it off. Eventually the screw head broke.
After some brute force with the pliers, I eventually got the screw to back out, but not before the valve turned over a hundred times. It's a B Type valve.
I got a handle on and everything works but the valve keeps turning. The hot water is at about 8:00. Any higher or lower it's not very hot. At that position, it seems just hot enough. I recall it getting hotter before.
Is this going to be a problem during inspection when I sell my house? About to list it.
(I have the other thread on the drain issue)
