Can't remove shower strainer
kdrymer
Aug 16, 2014
Hello I am having trouble figuring out how to remove the strainer for my shower. As you can see in the pictures there is no visible screws to remove the strainer. I started to use a screwdriver through the center slot in the strainer to see if it would turn and all it did was start to deform the metal so I stopped. Do I need to pry the part going around it first with a screwdriver? Appreciate any feedback.
What/where are the pins you are referring to? I should also add that this is a manufactured home (not sure if that matters in this situation)
