Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Drain pipe re-plumb?
Thread Tools Display Modes
Old 07-29-2014, 09:05 PM   #1
Pablo1915
Default Drain pipe re-plumb?
I have a pvc, 4/4/2, "Y", with an adapter glued into the 2 side. The adapter allows for a threaded 1/2" pipe. I would like to some how, change the 1/2" opening in the adapter, to allow a 3/4" pipe to enter. The 3/4" line is for the a/c drain. I can not remove the "Y". I would like the opening in the adapter to be 3/4". I do not want to run 3/4" pipe to the 1/2" opening. Is there a way to modify this glued in adapter to get a 3/4" opening for 3/4" pipe?
Pablo1915 is offline
Old 07-29-2014, 10:25 PM   #2
johnjh2o
johnjh2o's Avatar
Liked 726 Times on 550 Posts
Likes Given: 620
Is the 4x4x2 Y on a waste line? If so then a vented trap with an air gap for the AC line is required.
John
johnjh2o is offline
People Like This
Old 07-29-2014, 11:43 PM   #3
Pablo1915
Yes, it is a waste line. Is there a way to modify this glued in adapter to get a 3/4" opening for 3/4" pipe?
Old 07-30-2014, 04:27 AM   #4
SHR
Liked 282 Times on 214 Posts
Likes Given: 789
Quote:
Yes. Cut out the entire wye and replace with the correct size. Pay attention to what johnjh2o stated about the way this needs to be hooked up. It can not be hooked up how you appear to think it can.
SHR is offline
journeyman Likes This
Old 07-30-2014, 08:30 PM   #5
Pablo1915
I can not remove the "Y". Is there a way to modify this glued in adapter to get a 3/4" opening for 3/4" pipe?
Old 07-30-2014, 09:17 PM   #6
johnjh2o
johnjh2o's Avatar
Likes Given: 620
I for one will not give advice on how to make a illegal connection. I would suggest that you call a plumber. What you are planning on doing could put sewer gases throughout your home.
John
johnjh2o is offline
People Like This
Old 07-30-2014, 11:37 PM   #7
Pablo1915
I do not want to make an illegal connection. The a/c drain line is an existing drain line that has been there for 15 years. I just want to run 3/4" all the way to the "y" that now has a 1/2" adapter. Is there a way to modify this glued in adapter (described in original post) to get a 3/4" opening for 3/4" pipe?
Old 07-30-2014, 11:41 PM   #8
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
If there is not a vented trap with an air gap between the discharge and the trap, then it is an illegal connection, and for good reason.
None of us professionals are going to help someone do something that we know could be dangerous. Period.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
People Like This
Utility sink drain pipe attached to washer machine drain pipe pcanaveral Toilets and Sinks 1 12-28-2013 08:30 PM
Plumb Talk MrPavao General Plumbing Help 9 08-11-2013 11:27 PM
How to plumb a vanity sink Markcowie General Plumbing Help 5 01-16-2013 01:14 AM
Re Plumb with Pex digitalplumber General Plumbing Help 8 02-19-2012 04:59 PM
Re-plumb - now problems ramilin General Plumbing Help 3 07-28-2010 03:09 AM
Newest Threads
