Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Products > PEX - same brand for all necessary?
Thread Tools Display Modes
Old 07-25-2014, 05:42 PM   #1
bixnc
Default PEX - same brand for all necessary?
I read in a diy magazine that, ideally, all PEX components (tubing, fittings, etc.) need to be the same brand.
My intention is to use Watts cinch-clamps with a Watts tool. Does the tubing need to be Watts for the best compatibility?
I would think that if the different brands of tubing had that much inconsistency then they wouldn't be on the market to begin with.
bixnc is offline
Old 07-25-2014, 09:42 PM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
It would make it easier to go after a single company in the event of any kind of problem. Other than that, they are all supposed to be compatible as far as size. Some of the manufacturers manufacture proprietary fittings that need a special tool, some manufacturers make a special variety of pipe and fittings that use an expansion tool, but the ID and OD of the pipe is the same.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
johnjh2o Likes This
Old 07-26-2014, 05:12 AM   #3
SHR
Liked 283 Times on 215 Posts
Likes Given: 790
All PEX pipe has to meet the same standards. Watts insert fittings with cinch clamps will work with all brands of PEX. Expansion fittings like Uponer have to be used only with PEX-A. All other cinch or crimp fittings that I know of should work with any PEX and the corresponding insert type fittings.
SHR is offline
journeyman Likes This
What brand faucet is this? heynowjerry General Plumbing Help 1 06-20-2014 03:33 PM
Faucet Brand? Burns711 Toilets and Sinks 0 04-04-2014 01:15 PM
Tub faucet brand? AJay General Plumbing Help 17 03-20-2012 11:26 AM
Which brand? AJay General Plumbing Help 2 01-08-2012 02:09 PM
Which brand should I look at? wej76 Plumbing Products 20 03-20-2011 05:59 AM
Newest Threads
