Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > sink drain capacity
Thread Tools Display Modes
Old 07-15-2014, 11:22 AM   #1
Yeti
Default sink drain capacity
Shouldn't a sink be able to take all of the water that is capable of flowing out of the faucets, even if fully opened, without overflowing the sink? The sinks in question are in an old building that has back to back sinks in adjoining rooms.
Yeti is offline
Old 07-15-2014, 01:12 PM   #2
CT18
Liked 47 Times on 38 Posts
Things like clogged drains or vents will have a effect on it.
CT18 is offline
Old 07-15-2014, 03:32 PM   #3
SHR
Liked 282 Times on 214 Posts
Likes Given: 790
Quote:
"clogged drains" will cause the problem you have. Vents would have nothing to do with it.
SHR is offline
Old 07-16-2014, 01:43 AM   #4
Yeti
Thanks for the reply. I'm being told venting is the issue but I felt it was more of a slow drain issue. The problem is I'm not a plumber and the guy telling me it's the vent is a plumber. Thanks again.
Yeti is offline
Old 07-16-2014, 01:50 AM   #5
journeyman
the professional
journeyman's Avatar
Liked 150 Times on 117 Posts
Likes Given: 150
it is very rare if not ever a vent problem. the back to back sinks dump into a double san tee. The drain needs to be snaked out. i would get another opinion. why is the plumber saying it is a vent issue?
journeyman is offline
People Like This
Old 07-16-2014, 02:04 AM   #6
Yeti
I'm not sure why he is saying that. I suspect it's because he doesn't really know why and is just telling me it's the venting and there isn't anything he can do about it. (in-house plumber)
Yeti is offline
Old 07-16-2014, 02:24 AM   #7
SHR
Likes Given: 790
Quote:
Me thinks your in-house plumber does not have a license number.
SHR is offline
journeyman Likes This
Old 07-16-2014, 02:14 PM   #8
Yeti
Quote:
That is true. He has tested but has not passed yet.
Yeti is offline
Old 07-17-2014, 03:03 AM   #9
journeyman
the professional
journeyman's Avatar
Likes Given: 150
so you are taking advise from someone who claims to know the solution but cant pass the test. handyman and general contractors know just enough to be dangerous to you and them selves hire a true proffessional to the trade you need help with.
SHR Likes This
Sprague 1A gas meter capacity? Steven General Plumbing Help 1 08-09-2013 03:08 PM
Mystery drain hose into bathroom sink drain Electron2002 General Plumbing Help 22 05-23-2013 04:52 PM
Where should I buy my water softener from (and capacity question)? amateurplumber General Plumbing Help 1 03-14-2013 05:51 AM
How to add Utility Sink and Washer Drain to existing drain stack obriendigital General Plumbing Help 1 03-27-2011 02:15 AM
do I need more hot water capacity? how do I get it? starfish11040 Water Heaters and Softeners 8 02-25-2010 12:49 AM
Newest Threads
