Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Main Shutoff Valve Slow Leak
Thread Tools Display Modes
Old 07-15-2014, 03:41 AM   #1
Default Main Shutoff Valve Slow Leak
Hello all!
My first post here - hopefully some of you can help.
My shutoff valve to the main water supply has developed a slow leak. My wife said it's been a couple weeks (in laundry room) and she just let me know tonight.
I have not touched it at all except to turn the valve off and on again. I'm tempted to give the nut a turn with a wrench but concerned about making it worse. My assumption is the next level up to shutoff is at the street and that's beyond me.
A) Should I turn it to the right to tighten the connection? Not sure about any reverse threads.
B) Should I leave alone and call a professional plumber?
The pic attached should show the dark, wet part next to the nut.
Thanks in advance for steering me in the right direction.
skipsax is offline
Old 07-15-2014, 03:45 AM   #2
the professional
journeyman's Avatar
Liked 150 Times on 117 Posts
Likes Given: 150
yes try to turn the packing nut to the right and see if it will stop the leak. be careful and dont force it. it is probably loose. eventually it will need to be replaced
journeyman is offline
People Like This
Leak from toilet shutoff valve Kissimmee General Plumbing Help 3 04-01-2014 11:15 PM
Leak detection and well water shutoff system Lucky-Don Pumps and Wells 1 12-06-2013 09:08 PM
Leak Defender Well Water Shutoff System Lucky-Don Plumbing Products 1 11-07-2013 09:18 PM
Leak detection and well water shutoff system Lucky-Don Project Display 0 11-04-2013 04:19 PM
Is there a way to fix this dripping shutoff valve? ecrane99 General Plumbing Help 5 07-29-2011 05:02 AM
Newest Threads
