Our 1987 home is on a concrete slab.
To the best of my knowledge (based on Google search, as I have no plumbing experience), the toilet flange was installed at the wrong angle.
In the photo, the wall is parallel to the top of the pic.
The flange is attached (one piece) to a straight pipe that is approximately 6" long measuring from the joint to the top of the flange. Closeup of product info on flange:
The flange is not screwed or attached to the floor in any way. In fact, in an effort to unscrew the flange to possibly rotate it to the correct angle, I found there is no concrete in the area where the screws would mount. The flange is securely fastened (glued?) to the next pipe, as pulling up on the flange pulls that pipe as well. (There is about 1/8" step down between the 2 pipes).
Our previous toilet had been installed with the bolts through the 2 notches on the sides of the flange.
Also, we inadvertently discovered that our setup requires a 10 rough in toilet.
My questions are:
1. Is it advisable to replace the flange to properly reinstall, or are there other options for making this work?
2. Is there a (good) flange adapter to convert our setup from a 10 to a 12 rough in? If so, is the correct bolt placement necessary for this to works?
3. I am handy with no plumbing experience. Can I do this myself?
I am trying to wrap up this project asap and would welcome any and all suggestions. Cost is a primary concern.
Thank you!
Jenny
My questions are:
Thank you!
Jenny
