Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Pressure Regulator Install Help
Thread Tools Display Modes
Old 07-04-2014, 03:13 AM   #1
SnakeOut
Likes Given: 1
Default Pressure Regulator Install Help
Hello,
I need a suggestion on how to connect a water pressure regulator to my tap water source. The pressure regulator has an odd type fitting that doesn't match up to my water source. (see photo #1).
Detail:
I bought a new reverse osmosis unit. My home water pressure is almost 100 PSI, but the recommended water pressure for the RO unit is 65 PSI, hence the pressure regulator.
The short of it is that the regulator has 1/4" MIP female fittings for it's inlet and outlet. I wanted to connect the regulator to the cold water shut-off valve located under my kitchen sink. (See photos #3 & #4). My plan was to replace that existing cold side valve with a brand new one that has two male 3/8" OD (compression) fittings, exactly like the hot side currently does, (see photo #5). My plan was that one of the two outlets on the new valve will supply the cold side of my kitchen faucet, while the other outlet will go to the pressure regulator's "IN" side. (3/8" OD to 1/4" MIP). The out side of the regulator is good as I found a fitting that will connect the regulator to my RO unit, (see photo #2 with the red tubing attached).
I went to Home Depot looking for an adapter 3/8" OD to 1/4" MIP, but there ain't no such animal.
My shut-off valve for the kitchen faucet connects via a female 1/2" NOM compression fitting, (shown best in photo #3). The other side of the that fitting is soldered onto the copper coming from the wall.
If you can think of any way for me to bring the pressure regulator in-line with the water system then please let me know. I am pretty much stuck unless I force a wrong thread fitting into it with a bunch of glue. The regulator is made of plastic. Also I only want to regulate the RO unit, nothing else.
#1 Water Pressure Regulator, showing the 1/4" MIP fitting.
#2 Water Pressure Regulator with fitting attached for the down side flow to RO unit. The outlet is good. I just need to connect the inlet to a water source.
#3 The cold side valve that's going to need to be replaced.
#4 Full shot of the cold connection as it currently exists:
#5 Hot Side. My original plan was to replace the cold valve with this same type of valve:
Thanks for thinking about this. I appreciate it!
SnakeOut is offline
Old 07-04-2014, 12:20 PM   #2
phishfood
Liked 936 Times on 752 Posts
Likes Given: 1672
A short piece of 1/4" copper (3/8" OD) with a 1/4" male adapter soldered onto the end of it.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
SnakeOut Likes This
Old 07-04-2014, 12:22 PM   #3
johnjh2o
johnjh2o's Avatar
Liked 692 Times on 526 Posts
Likes Given: 580
There is a stop made with both 3/8" O.D. x 1/4" O.D. compression nuts. That's what you need.
John
johnjh2o is offline
Old 07-04-2014, 09:40 PM   #4
SnakeOut
Likes Given: 1
Quote:
Hello phishfood,
If I understand your post, you are suggesting to use 1/4 copper tubing, and solder slip fittings onto both sides to make my own adapter? If I could find both of those slip fittings then that sounds like the next best thing to finding an actual adapter fitting.
Thanks for your suggestion!
SnakeOut is offline
Old 07-04-2014, 09:45 PM   #5
phishfood
Likes Given: 1672
No, you only need to solder a male adapter on one end, the other end you can attach to the supply stop valve via a compression connection.
Old 07-04-2014, 09:51 PM   #6
SnakeOut
Likes Given: 1
Quote:
Hi johnjh2o,
I actually had that part, the 3/8 - 1/4 stop, in my hand. The problem is that 1/4" OD is not the same size as 1/4" MIP. 1/4" OD is much smaller than 1/4" MIP. So much so that the threads wont even make contact, it would just fall right out of the hole it's so loose.
I did verify that the regulator has 1/4" female MIP by finding a couple different fittings that fit it. Unfortunately those fittings were not what I needed. I just used them to identify the size of the tap on the reg.
SnakeOut is offline
Old 07-04-2014, 09:53 PM   #7
SnakeOut
Likes Given: 1
Gotcha, thanks.
SnakeOut is offline
Old 07-06-2014, 06:38 AM   #8
SnakeOut
Likes Given: 1
Ok guys,
Here is the Frankenstein job that I created (dry assembled) that connects that stupid regulator to my cold water supply.
Right side: To Reverse Osmosis Unit.
Left Side: To kitchen faucet.
Bottom: To water source.
Thanks again for your help. Now I get to go play with fire!
SnakeOut is offline
Pressure regulator replacement cordovan66 General Plumbing Help 5 03-21-2016 10:53 PM
Pressure Regulator Valve jujubee General Plumbing Help 5 05-26-2013 06:43 PM
Watts Pressure regulator does not hold water pressure GoshenPlumber General Plumbing Help 2 05-05-2013 12:27 PM
Pressure Regulator Seat skiwater9 General Plumbing Help 0 06-28-2011 07:46 PM
Newest Threads
