Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > using pipe joint compound on plastic threads
Thread Tools Display Modes
Old 07-02-2014, 08:06 PM   #1
AdrianH
Likes Given: 3
Default using pipe joint compound on plastic threads
Hi. I took my brass back flow preventer off my irigation system because I noticed it had a slow leak. I had used teflon tape so I went to the store and was given pipe joint compound and used that instead. Now it is female brass thread to male pvc thread, the pvc is the extra thick stuff.
However I just read the back of the pipe joint compound as I was putting it away and noticed it says do not use on plastic.
Whats the deal here, is it just because it might break if I try and undo it, or is it going to eat through it?
Thanks,
-Adrian
AdrianH is offline
Old 07-02-2014, 11:09 PM   #2
phishfood
Administrator
Liked 949 Times on 764 Posts
Likes Given: 1702
It is dependent upon the chemical makeup of the pipe dope. If the canister says not to use on plastic, then you should not. Some are OK on PVC but not on CPVC, some on both, some are not OK on any plastic.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
AdrianH Likes This
Old 07-03-2014, 01:39 AM   #3
SHR
Liked 264 Times on 199 Posts
Likes Given: 729
Use Rectorseal T+2 and be done with it. Good for use on any threads you will ever want to join.
SHR is offline
AdrianH Likes This
Old 07-04-2014, 06:41 PM   #4
AdrianH
Likes Given: 3
Thanks for the advice. I can't get it off now though its on there so good. I don't have those slip on wrench things. What do you think my chances are if I leave it on there? It's real thick 1 inch, even if it was weakened it's still pretty strong.
If I absolutly have to take it off I am going to have to cut off the section so I can use my vice to get it off, and then couple it back together.
AdrianH is offline
Old 07-05-2014, 03:57 PM   #5
havasu
Administrator
havasu's Avatar
Liked 1080 Times on 875 Posts
Likes Given: 303
If this is an exterior pipe, I'd just let it go and keep your fingers crossed.
havasu is offline
AdrianH Likes This
Leaking threaded pipe joint brimanley General Plumbing Help 0 10-30-2013 02:16 PM
ABS Vent Pipe Joint Leak Patrick1234 Showers and Tubs 4 05-14-2013 02:09 AM
Leaking Joint in Vent Pipe Axolotl General Plumbing Help 1 03-30-2013 06:50 PM
partial pipe joint glued snucky General Plumbing Help 2 01-13-2012 09:49 PM
Canít remove fitting cause of joint compound BobObobson General Plumbing Help 7 05-30-2011 08:02 PM
Newest Threads
