Cellular pvc cement
anjolive
Jun 28, 2014
I accidently (idiot) glued some pvc piping today for my pool and used cellular cement. I did not realize I was using this type until AFTER I glued all parts. The pvc will have chlorinated pool water running thru the joints I glued...Should I start over and use the plumbing type of cement or am I ok with this glue ? Thanks .....:confused:
I have no idea what cellular cement is, but without primer and the specific glue, I wouldn't use it until corrected.
Do you mean the cement that is intended for use on black piping insulation?
If so, I would cut out the parts in question and replace them using the proper cement and primer.
Not knowing anything about the glue you are talking about, I would have to err on the side of caution and recommend that you cut out the pipe and fittings in question and redo it.
  • Like
Reactions: SHR
