Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > how to cut 4" pvc well casing liner
Thread Tools Display Modes
Old 06-19-2014, 03:17 PM   #1
Default how to cut 4" pvc well casing liner
Hello all. A new neighbor bought a property with a new well already drilled. Well is 300' feet deep. It is 6" steel cased 100' and 4" schedule 40 (I think) to bottom. The question is the 4" PVC casing is all the way to the top of the steel casing. We need to use pitless adapters here with at least 6' of bury depth.
This means the PVC is about 8' too high measured from the bottom of the well. The pump people say the PVC needs to be cut off below the pitless adapter.
Question is how does one cut the PVC after it is installed?
Original guy who did well is gone. No longer in town.
dablooch is offline
Old 06-20-2014, 09:31 PM   #2
Liked 744 Times on 565 Posts
Likes Given: 203
If you have to dig it down that far, cut the casing right off below where the pitless has to go and remove the liner. Weld a 6" well ring coupling on and install your pitless adapter as per normal.
Matt30 is offline
Liner for 2 1/2" PVC Drain Pipe?? StrongEagle General Plumbing Help 5 05-02-2014 04:23 PM
Bad liner mix permoliner Drain and Sewer Cleaning 6 08-24-2013 03:33 AM
new well casing depth bricklayer Pumps and Wells 2 08-13-2013 01:23 PM
PVC well casing questions stevehull Pumps and Wells 16 01-25-2013 11:36 PM
Shower Pan Liner jasmiesharris Showers and Tubs 2 01-21-2011 03:35 PM
Newest Threads
