Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Kitchen drain pipe stuck
Thread Tools Display Modes
Old 05-12-2014, 10:24 PM   #1
ihatepipes
Default Kitchen drain pipe stuck
I had to replace the trap in my kitchen sink, and when I did that the pipe that goes to the drain broke. So now I'm trying to replace that darn thing.
It's stuck. It's metal, looks like chrome maybe? Silvery.
I tried some CRC multi purpose silicone stuff, still stuck. Found some STP stuff too, it said nothing about pipes but it had stuff in it like I heard stuff for pipes did, so I tried it anyway. Let it sit for 15 minutes, nothing. I'm going to get PB Blaster or something at my Orscheln's, we'll see.
ihatepipes is offline
Old 05-14-2014, 10:04 PM   #2
ihatepipes
I sprayed a lot of PB blaster on it a few times, I can't tell if it's looser or if it always moved a little bit and I just didn't notice it before.. It's still really stuck.
Old 05-14-2014, 10:13 PM   #3
johnjh2o
johnjh2o's Avatar
Liked 707 Times on 539 Posts
Likes Given: 594
Post a picture. It may be soldered into a copper waste line.
John
johnjh2o is offline
Old 05-17-2014, 06:47 PM   #4
ihatepipes
Here you go:
And closer:
I can't tell what the part under it is, it doesn't look like copper. I can't see in it very well.
Old 05-17-2014, 06:52 PM   #5
johnjh2o
johnjh2o's Avatar
Likes Given: 594
It should just pull out. Try twisting it as you pull it up.
John
johnjh2o is offline
SHR Likes This
Old 05-17-2014, 10:38 PM   #6
SHR
Liked 264 Times on 199 Posts
Likes Given: 729
If the tubular drain will not come out, I would use at least a 14" pipe wrench and remove the galvanized nipple the drain tubing goes in to. Replace the nipple with a similar length new nipple and attach a piece of 1 1/2" PVC with a stainless steel shielded Fernco coupling in order to put a sanitary tee at the top and add an AAV to eliminate the S-trap I bet you have.
SHR is offline
Old 05-18-2014, 04:38 AM   #7
journeyman
the professional
journeyman's Avatar
Liked 139 Times on 109 Posts
Likes Given: 141
Or cut the tubular close to nipple then use a hacksaw and cut inside tubular and split pipe. Be careful not to cut into galvanized pipe. Only use this if you cannot pull it straight out
journeyman is offline
Old 08-27-2014, 12:09 AM   #8
ihatepipes
I forgot about this thread, I just got one of those rubber connector things you tighten with a screw driver to slip over the pipe to connect to my trap. It works good, I'll just leave the pipe there unless I need to do something else with it.
Stuck handle and cap kitchen sink ksbsr6gn General Plumbing Help 5 01-15-2014 08:34 PM
Kitchen sink drain pipe valve? waffles General Plumbing Help 14 10-17-2012 04:48 AM
fork stuck in kitchen garbage disposal and unjammable blackcheetah General Plumbing Help 4 01-17-2012 02:34 AM
Loose Drain Pipe Below Kitchen Sink :( DukeStratosphere General Plumbing Help 5 02-17-2011 07:10 AM
Stuck Auger Bit in Pipe TxBuilder General Plumbing Help 5 01-13-2010 12:01 AM
Newest Threads
