Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Water Heaters and Softeners > Brand new water heater corrosion
Thread Tools Display Modes
Old 04-23-2014, 05:17 PM   #1
wallis
Liked 1 Times on 1 Posts
Default Brand new water heater corrosion
Hello everyone - thanks in advance for any help/suggestions/advice. I don't know a lot about water heaters but am slowly learning as I go.
About three weeks ago, I had a brand new Whirlpool 40 gal electric water heater installed. About a week later, I noticed brown rust colored water coming out of the hot water faucets when I turned on the water first thing in the morning after the heater had sat unused overnight about 8 hours. If I went out of town for a few days and the heater was sitting unused for a longer time, then the rust colored hot water would be a darker brown color.
The rust colored hot water flows for less than five seconds when the hot water first makes it to the faucet. The water then becomes clear after a few seconds. I first noticed this about a week after installation and this has continued happening for the last couple of weeks.
This happens in all the hot water faucets in the house. I opened the T&P valve and this also discharged rusty water for a couple of seconds before the water became clear.
There is no problem with the cold water. My previous water heater did not have this problem. I have city water supply, no softener, set to 120 degrees.
I read that corrosion can occur at the hot water outlet if a dielectric union is not used with copper pipes, but my condo has CPVC pipes so I'm thinking that should not be an issue for me? Also not sure where rusty water coming out the T&P valve fits into the equation.
Would corrosion inside the heater tank body occur this quickly (in a week or less) - isn't the anode rod supposed to reduce this, at least at first? Maybe a short or stray current in the new water heater is causing corrosion this quickly?
So, not sure what to do or who to call next. Maybe call the handyman who installed the heater and have him check the connections for corrosion even though I do not have copper pipes? Maybe call Whirlpool and see if they will replace the heater and hope that this heater was the problem and the new one will work properly?
Attached some pics - the expansion tank is about 6 years old - used on old heater without issues. Installer checked it and did not feel that it had to be replaced.
IMG_20140417_134434953_HDR (Small).jpg   IMG_20140417_134622154_HDR (Small).jpg
wallis is offline
Old 04-24-2014, 03:44 AM   #2
journeyman
the professional
journeyman's Avatar
Liked 143 Times on 112 Posts
Likes Given: 148
Is the whole house pvc? Are you sure it is a new tank. As much as I hate to say it people are not always honest.
journeyman is offline
Old 04-24-2014, 05:20 PM   #3
wallis
The whole house is PVC. Heater bought new at Lowes - I picked it up myself and looked new when taken out of the box.
The tee connecting the expansion tank to the heater is steel and is attracted to a magnet. I will have this checked for corrosion.
This was the same tee used for 5-6 years with my previous heater and had no issues then so not sure why it is causing problems a week after new heater installed but will check it anyway.
wallis is offline
Old 04-24-2014, 07:19 PM   #4
johnjh2o
johnjh2o's Avatar
Liked 723 Times on 547 Posts
Likes Given: 616
I may be wrong but it looks like you have CPVC pipe coming out of the wall with PEX to the heater. PVC is not allowed inside a dwelling.
John
johnjh2o is offline
Old 04-25-2014, 12:20 PM   #5
IFIXH20
HERE TO HELP
Liked 236 Times on 187 Posts
Likes Given: 165
The rust/color might be coming from your water lines. I have seen cpvc pipe with rust lining the inner pipe (rust from the water). The hot water line was drained when installing the water heater causing the rust to dry a little inside the piping. When the hot side water lines refilled the dry rust get washed and the lines have rust colored water. Run all fixtures at the same time for 20 min or so to flush the system.
IFIXH20 is offline
Old 04-25-2014, 03:51 PM   #6
wallis
OK I will try that.
wallis is offline
Old 05-01-2014, 08:31 PM   #7
wallis
Problem solved - the "T" connecting the expansion tank to the heater was steel which had rusted. Replaced it and water no longer rusty.
wallis is offline
IFIXH20 Likes This
Eccotemp Brand Tankless Water Heater StevenW1969 Water Heaters and Softeners 4 07-01-2013 01:16 PM
Water heater feed pipe shot. and now i have to replace my whole heater. chucksrt Water Heaters and Softeners 1 05-20-2013 01:14 AM
pipe corrosion on w/h intake olduglyguy General Plumbing Help 2 01-27-2013 09:16 PM
Will a water softener protect from corrosion in pipes? Arrowman Water Heaters and Softeners 2 10-05-2011 11:27 PM
water heater brand yny Water Heaters and Softeners 9 06-16-2011 02:20 AM
Newest Threads
