Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > New anti-siphon valve on hose bib leaks
Thread Tools Display Modes
Old 04-22-2014, 10:29 PM   #1
sparky472
Established Member
Default New anti-siphon valve on hose bib leaks
As in the title, just installed a new vacuum breaker on a new ball valve hose bib. The valve leaks where the valve threads onto the hose bib (left side of pic). Is this just normal for these valves? Or should I take the bib and valve back and ask for an exchange on both? ThxClick image for larger version
Name:	ImageUploadedByPlumbing Forum1398205774.423024.jpg
Sent from my iPhone using Plumbing Forum
sparky472 is offline
Old 04-22-2014, 10:48 PM   #2
havasu
Administrator
havasu's Avatar
Liked 1080 Times on 875 Posts
Likes Given: 303
Did it have the rubber washer on it?
havasu is offline
Old 04-22-2014, 10:52 PM   #3
sparky472
Established Member
Yep
Old 04-22-2014, 11:11 PM   #4
havasu
Administrator
havasu's Avatar
Likes Given: 303
I'm going to stick my neck out and say that it was probably tightened too tight, forcing the washer out of the intended area, allowing the leak.
havasu is offline
Old 04-23-2014, 12:50 AM   #5
Caduceus
Caduceus's Avatar
Liked 348 Times on 254 Posts
Likes Given: 230
Or on the other side of the spectrum, it may have been cross threaded and isn't tight enough. Also, if it has a tamper-proof screw on the side be sure it is taken out before installing so that it doesn't drive into the threads and give you the impression that it is tight. Then you can reinstall the tamper-proof screw if you choose.
I usually can put those on hand-tight and they don't leak because of the washer that havasu mentioned.
Caduceus is offline
phishfood Likes This
Old 04-23-2014, 12:53 AM   #6
Caduceus
Caduceus's Avatar
Likes Given: 230
I'm curios if the photo you provided is the actual bib w/vacuum breaker? If so, it doesn't look like it's threaded all the way on and the tamper-proof set screw is already set in place.
Caduceus is offline
SHR Likes This
Old 04-23-2014, 01:20 AM   #7
sparky472
Established Member
It wasn't cross-threaded, I'm certain. I screwed it on hand tight. It was leaking when I turned it on. I tightened further at that point. Still leaking. I guess I'll need to start over when I have time.
Old 04-23-2014, 03:11 AM   #8
journeyman
the professional
journeyman's Avatar
Liked 139 Times on 109 Posts
Likes Given: 141
I am thinking maybe it is double gasketed and is not threading on all the way. Or you ovrr tightened and cracked the brass
journeyman is offline
Old 04-23-2014, 03:40 AM   #9
havasu
Administrator
havasu's Avatar
Likes Given: 303
I just installed a bunch of those anti-siphon gizmos, and found a light coat of silicone aided in threading it, since the manufacturer had horrible, rough threads.
havasu is offline
Old 04-23-2014, 09:47 PM   #10
SHR
Liked 264 Times on 199 Posts
Likes Given: 729
Quote:
According to the picture you attached, the vacuum breaker is not even close to tight. I have never been able to still see hose bib threads after I installed a vacuum breaker. Did you use a pliers or channel lock-type tool to tighten it? It's not tight enough.
SHR is offline
toilet valve shut, but still leaks needstlc Toilets and Sinks 14 04-22-2014 05:12 PM
Hot water heater leaks from the t & p relief valve Kmason Water Heaters and Softeners 5 02-12-2013 12:41 AM
Champion Anti-Siphon Valves? Michael_1265 General Plumbing Help 3 02-15-2012 06:44 PM
Anti Siphon bib too close to wall Bulldog General Plumbing Help 7 06-15-2010 07:38 PM
Anti-siphon valve needed? jakeotr General Plumbing Help 0 03-21-2010 12:54 AM
Newest Threads
