Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Running new water line from main
Thread Tools Display Modes
Old 04-04-2014, 05:19 PM   #1
clarehills
Liked 1 Times on 1 Posts
Default Running new water line from main
Hi,
I plan on running a new copper pipe from the main water line. I intend to add a T junction just after the pressure regulator. The main line is a 1" internal diameter pipe but the current pipe that feeds the hose (that I will T off) has an internal diameter of 3/4".
Question: Should I use a 3/4" or 1" pipe for the new pipe?
I plan on replacing all the pluming (both hot and cold water) in the house using this new line.
Thoughts?
Thanks,
Clarehills
clarehills is offline
Old 04-04-2014, 08:49 PM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
Without knowing all of the details of the plumbing in your home, it would be safe to say that keeping it 1" is the best idea. You can always reduce the size of the pipe at the hose connection and as you repipe to other fixtures.
Caduceus is offline
Old 04-05-2014, 05:31 PM   #3
clarehills
That was my guess but wanted to check with you guys first. Thanks very much!
Clarehills.
bellies in the main line mks_97 Drain and Sewer Cleaning 4 11-20-2011 06:06 PM
Running gas line for new oven jpbusch General Plumbing Help 8 09-22-2011 07:02 AM
Replace main water line Cuda General Plumbing Help 3 05-12-2011 09:13 AM
Need to splice into main copper water line...help? Chris4 General Plumbing Help 2 03-19-2011 03:44 PM
Relocating Main Water line through attic jbobst General Plumbing Help 1 02-10-2011 12:42 AM
Newest Threads
