Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Building Code > Plumbing Code By State
Thread Tools Display Modes
Old 04-02-2014, 02:33 PM   #1
Zanne
Zanne's Avatar
Liked 186 Times on 166 Posts
Likes Given: 3352
Default Plumbing Code By State
I was curious about which states follow which plumbing code and found this on the forums at terrylove.com and filled in and changed based on http://www.tests.com/State-Plumbing-Codes-License
Alabama IPC adopted by Local Governments
Alaska UPC adopted at State level but IPC in use locally
Arizona UPC adopted at State level but IPC in use locally
Arkansas uses IPC
California is based on UPC
Colorado uses IPC
Connecticut IPC effective Statewide
D.C. IPC effective in city
Delaware IPC effective Statewide
Florida IPC effective Statewide
Georgia IPC effective Statewide http://www.plumbingpros.com/pdf/dwvents.pdf
Guam uses IPC
Hawaii uses UPC
Idaho uses IPC
Illinois Develops their own code but IPC adopted by Local Governments
Indiana uses the Indiana Plumbing Code (as of 2012 it used 2006 IPC second printing)
Iowa IPC adopted by Local Governments and statewide
Kansas uses IPC
Kentucky State Plumbing Code based on IPC precursor
Louisiana State Plumbing Code based on IPC precursor
Maine IPC adopted by Local Governments
Maryland uses IPC
Massachusetts uses UPC, 248 CMR 10.00.
Michigan IPC effective Statewide
Minnesota uses Minnesota Plumbing Code
Mississippi IPC adopted by Local Governments
Missouri uses UPC
Montana uses UPC
Nebraska uses IPC
Nevada uses IPC
New Hampshire IPC effective Statewide
New Jersey uses NSPC
New Mexico uses the New Mexico Plumbing Code based on UPC
New York IPC effective Statewide
North Carolina IPC effective Statewide
North Dakota uses IPC
Ohio IPC effective Statewide
Oklahoma IPC effective Statewide
Oregon uses the Oregon Specialty Plumbing Code based on UPC
Pennsylvania adopted IPC
Puerto Rico IPC effective Statewide
Rhode Island IPC effective Statewide
South Carolina IPC effective Statewide
South Dakota uses UPC
Tennessee IPC effective Statewide
Texas IPC at State but Austin, Houston, San Antonio use UPC
The Texas State Board of Plumbing Examiners recognizes the 2006 editions of the UPC, IPC, & IFGC which means each city or town in the state can either adopt the UPC or IPC/IFGC regardless of edition.
Utah IPC effective Statewide
Vermont Use 1990 BOCA (BOCA now under IPC)
Virginia IPC effective Statewide
Washington uses UPC
West Virginia IPC effective Statewide
Wisconsin Plumbing Code Link
Wyoming Both IPC & UPC used by Local Governments
http://gisceu.net/PDF/U103.pdf
Changes made to Louisiana plumbing code in 2013
Louisiana does not allow AAVs and the allowable distance from trap to vent in a 2" drain was reduced from 8' to 6'.
Any corrections or additions?
Zanne is offline
Old 04-04-2014, 09:02 PM   #2
Caduceus
Caduceus's Avatar
Liked 350 Times on 255 Posts
Likes Given: 230
Additionally, Pennsylvania has more strict local plumbing codes in the Philadelphia and Pittsburgh regions.
Caduceus is offline
Zanne Likes This
Old 04-05-2014, 07:08 PM   #3
Zanne
Zanne's Avatar
Likes Given: 3352
Thanks! When you say "more strict" what do you mean? More enforcement? Higher fines? Less leeway on the rules?
Zanne is offline
Old 06-12-2014, 01:59 PM   #4
jamescustom
Liked 3 Times on 3 Posts
Thanks for putting this together. I live in Washington state and trying to find a cheap copy of the UPC 2012. I used to do structural engineering and reading a code book is preferrable to asking a bunch of questions.
jamescustom is offline
Old 06-12-2014, 02:14 PM   #5
plbgbiz
plbgbiz's Avatar
Liked 65 Times on 46 Posts
Likes Given: 84
The Construction Industries Board for Oklahoma has adopted the IPC. However, individual municipalities are all on different years.
Additionally, there are as many interpretations of the IPC as we have inspectors. We cannot even get consistent answers within the same city sometimes.
plbgbiz is offline
People Like This
Old 06-13-2014, 12:44 AM   #6
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
Quote:
That kind of thing aggravates me to no end. I don't mind having to follow strict rules, but at least let me know what those rules are!
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
Zanne Likes This
Old 06-14-2014, 03:54 PM   #7
Zanne
Zanne's Avatar
Likes Given: 3352
I do wish that things were more uniform so it wasn't so confusing. The variations can really make things difficult, but that is how things go with bureaucracy.
It won't let me edit my original post, but the Virgin Islands territory uses UPC.
I have a revised list with nicer formatting. Should I post it in a later post and maybe have admins paste it in? Or should I just post it here in a later post?
Zanne is offline
Old 08-24-2014, 12:42 AM   #8
Mayo
Mayo's Avatar
? i am a Plumber in New Jersey and does anybody knows where can i get the app for the IPC . i have been trying to get it on line.....
Mayo is offline
Old 08-27-2014, 11:49 PM   #9
Zanne
Zanne's Avatar
Likes Given: 3352
Mayo, I'm not aware of any app for IPC... I take it you are looking for a copy of the current IPC to peruse? I wonder if any universities or government agencies have it in .pdf format or something. You might want to contact your local department of health/sanitation and ask about it. Otherwise, I'm not certain.
Zanne is offline
Old 12-16-2014, 07:09 PM   #10
frodo
Just call me Macgyver
frodo's Avatar
Liked 1844 Times on 1573 Posts
Likes Given: 381
http://www.ebay.com/sch/sis.html?_nk...+in+PDF+Format
frodo is offline
Zanne Likes This
Florida Plumbing Code app jseve Plumbing Building Code 1 01-22-2014 08:20 PM
2010 California Plumbing Code and calculating copper size?? mcintoshmc Plumbing Building Code 5 03-09-2013 11:06 PM
Plumbing code drain ? bhamiltonjr General Plumbing Help 12 02-12-2012 03:57 AM
MA Plumbing Code - Min Offset ravalhardikm Plumbing Building Code 1 11-02-2010 06:10 PM
Newest Threads
