Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > General Plumbing Help > Physically impossible problem!
Thread Tools Display Modes
Old 03-30-2014, 09:16 PM   #1
Huyt
Liked 1 Times on 1 Posts
Likes Given: 1
Default Physically impossible problem!
I am beaten. Here are the facts:
My NJ home had an extra bathroom added before I bought it. In this bathroom are twin basins and a tub/shower. All of the fixtures are made up of two faucets and a spout, so no mixer valves.
When we bought the house the shower was fine. Then it started intermittently running cold on people when other faucets still produced hot water.
Since then the problem has become permanent.
Right now the water from that shower/tub comes out at 100 degrees with just the hot faucet open. The water from the hot basin faucets in that same room produce hot water at 130 degrees.
I assume that somehow, somewhere cold water is entering the pipe supplying hot water to that bath. I have turned off the water to the kitchen mixer tap. No help. In the master bathroom I have done the same to the mixer taps in the basins. No help. I have turned the master shower mixer to fully cold, but can't find a way of actually isolating that valve.
Is there a way I could isolate that mixer by taking off the face plate?
BUT I assume that the new bathroom shower/bath and basins are all supplied by the same line. So if cold water is reaching the hot-water pipe to the bath why is the hot water in the basins not affected?
All the hot water comes from one gas-powered unit in the basement.
Only that one tub/shower is affected.
Should I be calling an exorcist?
Cheers
Huyt
Huyt is offline
Old 03-31-2014, 12:23 AM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
I believe that it has been a LONG time since tub/shower valves that aren't pressure balanced have been legal to install. Can you post a picture of your valve?
Regarding the basins not being affected, the tub valve usually pulls much more water than does the lavatory faucet, so it will usually show a cross over problem before a sink faucet will.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
People Like This
Old 03-31-2014, 05:01 PM   #3
Huyt
Likes Given: 1
Dear Phish
Here's the shower.
What other possible causes of crossover problems are there?
Thanks
Huyt
Huyt is offline
Zanne Likes This
Old 03-31-2014, 05:52 PM   #4
SHR
Liked 282 Times on 214 Posts
Likes Given: 790
Ahh, the mixing valve is right there on the shower wall in your picture. It seems you have a very common, easy to solve issue. Remove the mixing/pressure balancing cartridge from behind the faucet handle on the right (I think it should be bottom) in the picture. Bring the cartridge to your plumbing supply store and match it up to a new cartridge. If you can identify the brand, you should be able to order one free from your manufacturer. Replace the cartridge and I bet your problem will be solved.
SHR is offline
People Like This
Old 04-01-2014, 03:19 PM   #5
wood4d
Liked 2 Times on 1 Posts
the shower valve has a temperature limiter under the handle which is removed with an allen wrench. After removing the handle the adjustment is very fast to do. The other valve looks like an on/off for the handshower.
wood4d is offline
People Like This
Old 04-09-2014, 01:27 AM   #6
Huyt
Likes Given: 1
OK, I have isolated (turned off both hot and cold supply) the washing machine, mixer faucets in both master bathroom lavatories and the master shower, the kitchen mixer faucet, the third bedroom mixer shower and the laundry mixer faucet. There are no more places with mixers. All the rest are separate spigots for hot and cold water.
The problem shower/bath (which is not a mixer valve) still maxes at about 112 degrees, but the lavatory faucet next to it reaches 150 degrees.
Is there any safety valve or other such item that could be installed out of sight and which could cause this cross-over problem?
Thanks again
Huyt
Huyt is offline
Old 04-09-2014, 03:59 AM   #7
SHR
Likes Given: 790
Quote:
Quote:
You have been given the answers to your query. It seems you have done a lot of messing with your faucets but you do not mention trying the solutions you were provided.
SHR is offline
Old 04-09-2014, 02:08 PM   #8
Huyt
Likes Given: 1
I believe that have indeed done what was asked. The photo was of the master bath shower. I isolated that one (mercifully it had little shut-off screws by the valve). The shower that runs cool is not a mixer valve. So I can't change that cartridge.
Or have I misunderstood something?
Huyt is offline
Old 04-09-2014, 03:28 PM   #9
journeyman
the professional
journeyman's Avatar
Liked 150 Times on 117 Posts
Likes Given: 150
You have to remove the handle and pull out the cartridge and install a new one that is what shr is referring to
journeyman is offline
Old 04-09-2014, 10:16 PM   #10
Zanne
Zanne's Avatar
Liked 186 Times on 166 Posts
Likes Given: 3352
http://homeguides.sfgate.com/replaci...dge-57457.html
You can google how to replace shower lever cartridge and there are many videos to show you how to remove the lever.
Those are interesting tiles with the little symbols on them. Its neat.
Zanne is offline
goulds pump problem or well problem? gg05 Pumps and Wells 3 05-04-2012 12:36 PM
Newest Threads
