Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Plumbing Products > pipe materials
Thread Tools Display Modes
Old 03-18-2014, 01:45 AM   #1
Homesto
Likes Given: 1
Default pipe materials
iím building a house and am interested in what piping materials (PVC, copper, PE, PPR) would be best for each application. what would you recommend for wastewater? hot water? gas? what are the relative advantages and disadvantages for the materials for cost, durability, ease of putting together etc?
thanks
Homesto is offline
Old 03-19-2014, 12:33 AM   #2
phishfood
Administrator
Liked 965 Times on 775 Posts
Likes Given: 1739
PVC for drainage.
Copper (if you have good water, or filter it well) or PEX for water distribution.
Black iron for gas.
Lake County, Florida plumber
Springtime Plumbing Services
phishfood is offline
SHR Likes This
Old 03-20-2014, 02:18 PM   #3
plumbdrum
Banned
Liked 17 Times on 16 Posts
I agree with fish, please advise your plumber to stay away from CSST!!!!!!!
Sent from my iPhone using Plumbing Forum
plumbdrum is offline
Old 03-20-2014, 11:58 PM   #4
Matt30
Liked 734 Times on 557 Posts
Likes Given: 199
Just a question from a plumber north of the border....
Everything i have seen from guys posting pictures on here from the USA is white PVC. Do you ever use ABS?
Matt30 is offline
Old 03-21-2014, 12:41 AM   #5
Chris
Administrator
Chris's Avatar
Liked 931 Times on 786 Posts
Likes Given: 67
In CA all drain plumbing is ABS and they transition when it comes out of the wall to that thin wall prettier stuff.
Chris is offline
Old 03-21-2014, 02:36 AM   #6
phishfood
Administrator
Likes Given: 1739
ABS is only used in mobile homes (trailers) down here. I know it is popular in other parts of the country, but I have no real experience with it.
Old 03-21-2014, 03:10 AM   #7
Chris
Administrator
Chris's Avatar
Likes Given: 67
What do you guys use under the slab of a home?
Chris is offline
Old 03-21-2014, 05:47 AM   #8
alefromitaly
alefromitaly's Avatar
Liked 258 Times on 211 Posts
In Europe we can choice between these two..
alefromitaly is offline
Old 05-13-2014, 08:31 PM   #9
davidplumberman99
pex is good for new houses
davidplumberman99 is offline
Old 05-13-2014, 10:08 PM   #10
plbgbiz
plbgbiz's Avatar
Liked 65 Times on 46 Posts
Likes Given: 84
Schedule 40 PVC for the drainage system. NOT FOAM CORE! If your plumber thinks you should have foam core PVC, FIRE HIM!
Uponor for hot and cold water supply.
Schedule 40 black steel pipe for the gas.
If the plumber suggest CSST gas tubing, treat him as though he suggested foam core PVC, FIRE HIM.
plbgbiz is offline
exposed gas pipe in closet/strapping gas pipe in attic redbandit98 General Plumbing Help 0 12-05-2013 08:11 PM
Gas line materials question... KMorley Plumbing Building Code 15 01-13-2012 08:24 AM
Toilet PVC drain pipe came loose from pipe that leads to sewer. tireshark General Plumbing Help 6 08-02-2011 01:20 AM
Need to cap off an iron water pipe 3/4 for renos, do I need to thread the pipe? drchalifax General Plumbing Help 1 05-20-2011 09:04 PM
Sewer Pipe Replacement - liners vs pvc (aka pipe bursting) 914 General Plumbing Help 10 08-19-2010 01:07 AM
Newest Threads
